This command configures the option interface-id as described in RFC-4649 to an IPv6 bootp relay/DHCP relay agent.
bootprelay | BOOTP Relay Service |
ipv6 | DHCPv6 BOOTP Relay Service |
option | DHCPv6 BOOTP Relay options |
interface-id | Interface identifier option. |
interface_id_string | Interface identifier string. |
none | Identifier defaults to 802.1Q VLAN ID. |
all | All VLANs. |
802.1Q VLAN ID if not configured.
Use this command to configure the option interface-id as described in RFC-4649 to an IPv6 BOOTP relay/DHCP relay agent. After receiving an IPv6 BOOTP/DHCP request packet on the specified VLAN, the agent adds the configured identifier to the packet and passes it to the server. If this option is configured to be as system-name, the switch name is used as the remote-id. The same can be unconfigured using the none option. After unconfiguring this option, the switch MAC address (the default value) is used as remote-id. This option can be configured or unconfigured to a specified VLAN or to all VLANs.
* Switch # show bootprelay ipv6 BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default" BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7334 2001:0db8:85a3:0000:0000:8a2e:0370:7335 2001:0db8:85a3:0000:0000:8a2e:0370:7336 2001:0db8:85a3:0000:0000:8a2e:0370:7337 VLAN "Default": BOOTP Relay : Disabled VLAN "v1": BOOTP Relay : Enabled Interface ID : v1-12 Remote ID : v1_remId VLAN "v2": BOOTP Relay : Enabled Interface ID : 100 (Default) Remote ID : 00:04:96:52:A7:1B (Default)
This command was first available in ExtremeXOS 15.5.
